Hi, my aerox went 50kmh at best and I just put a stage 6 pro replica pipe on it. Now it goes sweaty in its 25kmh, what could be the reason? The moped is yamaha Aerox naked 2014ยจ and the moped is otherwise completely standard. I must also say that some hose came out of the standard pipe that I plugged because there was no place for it in the new pipe. I really need help with this one.
My yasuni had 2 restrictors in it when i bought it, one in the front of the pipe like you have removed, and also one in the tail pipe. so worth checking for that The stage 6 pro rep exhaust is quite a peaky pipe, and will need quite light rollers to get it in the power band. also if its sluggish pulling away you will need stiffer clutch springs.
