Yamaha Aerox 100cc Jetting Issue
Discussion in 'General Tuning' started by Mert Elidüzgün, Mar 5, 2020.
  1. Mert Elidüzgün
    Mert Elidüzgün New Member
    Hi fellas! I did lots of modifications on my Yamaha Aerox 100cc AC to run faster but she doesn't run well than I expected even standard setup was running better... I upgraded her without re-jetting the carb and I want to learn about which main jet size should I use. What are your recommendations that you guys can give?
    Modifications;
    • Malossi sport 124cc Cylinder Kit
    • Malossi PHVB Dellorto 22mm Carburetor ( Main Jet 78 )
    • Malossi E18 Pod Air Filter
    • Tecnigas Next-R
    • Malossi Multivar 2000 with 6gr Rollers
    • Malossi Primary Gear Up Kit
    • Doppler Boost Bottle
  2. scubabiker
    Damjam or whatever his name is, he is a God when it comes to setup advice
    Mert Elidüzgün likes this.
  3. Stevep
    Grab a couple of boxes of jets ranging between 90 and 130, start at the biggest and work your way down the sizes one by one, it's a tedious business but the rewards are great.
    You'll know when you hit the right size, it'll zing of the line
  4. Mert Elidüzgün
    Hey guys thanks for the reply! I find 105 and 95 size then i tried them. When i put the 105 on it she doesn’t even want to pull. Then i tried 95 she went well but it felt ilke she could go better! I think i should go for smaller size right ? Maybe around 92-90-88
  5. Stevep
    95 to 105, or vice versa, is a bigger jump than you think. That's why I said work your way down one size at a time
  6. Mert Elidüzgün
    You are right mate but i am new to that when i put the 105, on the full throttle engine peaks about 4200rpm and she didn’t want to pull. What is the reason? With the 95 she runs well. Maybe i should play around between 85 and 100 right?
  7. Peter N
    Peter N New Member
    How did you go with your jetting Mert. ????
    Im trying to work mine out. currently have 113cc big bore with Dellorto 22mm PHVB carb, with no filter I got to a 155 main, now ive got a filter I need to drop the main size down to match the air volume so searching the world for answers, just like yourself.
