wtf? can't be right can it? Brake noise
Discussion in 'General Scooter Discussion' started by [-Jebus-], Dec 6, 2008.
  1. [-Jebus-]
    [-Jebus-] Member
    Changed brake pads in the ped a few week back now cos they were metal on metal, then coming out of the mighty asda before (was buying tomorrows dinner for work lol) they were making a grinding noise again, no way can i need some new ones already?
    or is there something stupidly wrong with my brakes? lol
  2. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    copper grease on the back of pads? disc excesivelly worn, can you feel grooves when running your finger along the disc?
  3. [-Jebus-]
    [-Jebus-] Member
    i'll try that tomorrow - running finger over disc - shouldn't be worn like... could be though... copper grease on back of pads? fuck knows, dad fitted them for me - he'l be getting a slap if there is haha,
    aint trying it now, too cold to go outside and i'm wearing a pair of shorts so fuck that..
    any other suggestions? :D
  4. m1ck_t
    alot of shit
    copper grease SHOULD be applied, it should be on the back of pads, to stop the metal on metal squeeking.
    not much else to it mate
  5. [-Jebus-]
    [-Jebus-] Member
    ahh right ok then :p as you see i know shag all lol...
    the metal "Squeaking" ? what you mean by that, it just sounds like 2 pieces of metal grinding against each other as though they're worn down again...
    or is that what you mean by 'squeaking' ?
  6. capri dave
    capri dave Active Member
    could be rock salt on your pads...from gritting the roads..
    best to whip the pads out to check, if they are worn down already,
    you must have a sticking caliper, quite common this time of year ;)
  7. [-Jebus-]
    [-Jebus-] Member
    whats common? the rock salt or the calliper?..
    out of those 2 im guessing its the rock salt seems to be all our council spends fucking money on - even then the manage to get it everywhere but the road -.- usless twats lol
  8. m1ck_t
    alot of shit
    yeah that too, best thing to do really is to rebuild the calipers. dont even have to use new seals,
    just take the caliper off, split it, pull the piston out, take the seals out and in apot of brake fluid, clean the grooves thoroughly, clean the seals, seals back in, piston back in, fresh pads with copper grease on the back, caliper on, blead the brake.
    really is a 15 min job and improves brakes dramaticly, i done both of mine a few weeks back and will probs do it again before summer.
  9. capri dave
    the rock salt gets in every where, and its a corrosive,
    which means it starts eating away at your car, scooter what ever...
    when the grit/rock salt gets onto your pads/discs can make a scraping noise,
    similar to worn away pads...
    when it gets onto you brake pistons it causes them to stick, you may not even notice, untill your pads wear away in double quick time :msn1:
  10. [-Jebus-]
    [-Jebus-] Member
    ahhh right ok then guys thanks :)
    get my dad to sort it when he comes home tomorrow, bastard goes away for a weekend and my brakes decide they wanna make a funny noise, roads decide to try and throw me off, tyres decide to feel flat lol...
    oh well! :D back tomorrow, i'll get him to fix it hah
  11. capri dave
    im not sure what the set up is like on the aerox, but on the runner for example
    you have to take the rear wheel off before you can take the rear brake caliper off...
    but on a lot of peds...runner included, you cant take the rear wheel off without taking the exhaust off
    but if you just undo the rear wheel nuts almost all the way, it gives you enough free play to wangle the caliper out from inside the rear wheel ;)
    as i said not 100% sure if this applies to an aerox, ive never worked on one...
  12. [-Jebus-]
    [-Jebus-] Member
    to my knowledge at the minute it's only the front one doing it :p lol, and i need a new back tyre atm anyway - mines barely legal (considering you only need visible tread) thats how bad it is lol...
  13. capri dave
    yeahh best get a new one, other wise if your out in the rain at all,
    its going to be pretty slippery :wtf:
  14. wobbly_trials
    quite funny that, i know someone who drew the tread on his tyre before an MOT with permanent marker and it passed with just an advisory.
    personally below 1mm and its time to replace
  15. [-Jebus-]
    [-Jebus-] Member
    Lmfao wobbly seriously?! that's brilliant lol...
    and who changed the topic title =[
    and yeah dave it's slippy all the time, i'm scared to lean the bitch like i do in the dry (its constant rain up here almost) lol...
