right basically i wanted aerox forks on my speedy but found that the pole is shorter and thinner so to make it fit i would have to cut the pole out the aerox yoke and 1 out a speedy swingarm and weild the speedy pole in the aerox yoke! loads of work then i thought could i just bolt peugeot jetforce forks straight to a speedy?? i still dont know if i can but then i could bolt the aerox wheel to the jetforce yoke??? then some1 told me the jetforce spindle is thinner so then i thought jetforce yoke (if it fits speedy) with aerox fork legs would that work???
Re: coiuld i.... right ive recently fouund out that a peugeot vivacity forks are a straight swap ( thanks scootershack :lol: ) soo you could try and work with this?
Re: coiuld i.... lee u cudd do alot of things theres a few options,just choose one and get on with it,ill be at urs on saturday as long as the rox is playing ball, u cudd just roll with odd wheels i am lol make u different lol oh and dave i also told him tht last nite bt he diddnt seem interested!
yep cheers.... find a set of forks that bolt in, then messure the leg's of the forks you want to use, compair this to what ACTUALLY bolts to your bike. if its the same size then obviously use those forks.. there are a few options open to you, infact any right way up forks can be bolted in if there the correct diameter, travel and length can even be changed.. (application permitting of course as obviously you cant just cut down some gsxr forks to scooter length)
i know there are some that fit anf i know u can adjust anything but i would like something tht slots straifght in cos if i have to cut a weild there is a possibility that it will break or be bent i can do it im sure but would rather something tht slots straight in
get soem vivacity forks for now then... then you can fit them, ride your bike and then messure what diameter the legs are.. then somone with some aerox forks can messure theres.. there fairly thick tho..
ive got some aerox ones and a spare speedfight swingarm so i could just wait and weild but id rather something easier and i say some vivacity forks there tiny and rank
do yourself a favor.. dont go welding anything fork wise.. if it doesent bolt in its not worth fucking about wiht. can have a top tube/yoke made comparitvly cheaply wich will bolt in and take whatever forks you wish
