would any one like to look at my bike
Discussion in 'General Chat' started by Dwaine, Jan 4, 2014.
  1. Dwaine
    Dwaine Member
    piaggio zip
    ANY one in/near Nottingham..not sure whats up with it but today just dosent run right only dose around 25/30 full throttle..im loosing the will to live with the thing,,,probs some thing so simple i have no clue tho..only reason im stressing so much as need it to get to work Monday GGGGGGGGGGRRRRRRRRRRRRRRRRRRR
    piaggio zip
  2. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    what have you done to it recently? played with the carb? checked rollers?
  3. Dwaine
    Dwaine Member
    piaggio zip
    is it hard to check my rollers..also going to check my belt..but i do think its somat to do with the carb lol
  4. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    side the variator off, and make sure there are no flat spots on your rollers
  5. Dwaine
    Dwaine Member
    piaggio zip
    ok cheers mate ill crack on and check them soon then at least then i can rule the out with the belt then i no its deffo the carb witch im sure it is as garage fiddled with it.
