what will happen if a take my engine casing off so i can spray it ?? and what will happen if it take the engine casing bolts out ?? as i can get some nice anodized 1s for 50 pence :w00t:
the engine will seize, compression will be down, the crankshaft will break, bearings will split and the piston will split in two dont ever take the case of without proffesional supervision - many people have died trying to take the case off.......... :w00t: :w00t: :w00t: :w00t: :w00t:
no everything is secured with tightly fitted nuts, the problem isn't the parts coming off too easily, but too hard, to get at most things e.g. variator you have to you a impact wrench with hell of a lot of power, taking of the case is fine just dont get any water in there otherwise it will rust the parts inside
or in my mates case whos ped is now officially f**kd it will be filled with OIL WTF :rtfm: ???????? an 07 nrg power and hes had nufin but problems with it!
