wiring tnts on a typh
Discussion in 'Visual Modifications' started by ramo, Dec 22, 2010.
  1. ramo
    ramo GoldMember
    obviusly there is 2 wires coming out of each bulb. do i connect the live to either one of the two wires or are there certain wires for live and certain ones for earth?
    then do i just connect the two remaining wires together and then to earth (black wire)?
    and what do i do with the two extra wires (yellow and black i think) that plug in to the normal light?
    cheers
  2. tErr0
    Don't do it! Ugly things.
    The standard typhoon headlight has a sidelight and then a high and low beam on the main headlight bulb. So that's 3 lights but with a tnt light you only have two.
    The large connector should have 3 wires and the small one should have two.
    Forget about the small one and wire both the earths to the earth on the main connector and one of each of the live wires to the other wires. You should then have low beam as one of the lights and full beam as both.
    I haven't actually tried wiring up tnt lights as I think they look terrible and they don't put out much light so this is all a bit of a guestimation. But I can't see how it wont work.
  3. ramo
    ramo GoldMember
    sweet :good:
    ill post pics up of the wiring when im done incase anyone else has trouble figuring it out in the future
    ill probably change the tnts once i find a fresh standard light...whenever that is lol
