ive checked every forum i no can only find the pics of where the plugs go on the aprilia forum :rtfm: :rtfm: :rtfm: :rtfm:
its easy, the lines are wires and the other things are bulbs and electrical items (numbered on the right hand side)
already started wobbly got the indicator light high beam light and petrol light on now im confused im not using a petrol gauge and the oil light is weird because it goes to the petrol gauge
follow it on the diagram m8, key words at side so u know wiring color, dont forget that btw thanks for posting that its helped me out.
im still confused theres 1 wire for the oil 1 wire for petrol gauge and 1 wore for the dash board lights wheres the other wire for the oil light :rtfm: :rtfm: :rtfm:
SWITCHES 18. Ignition Switch/Steering Lock : lock-white/red and blue, ignition off-white/red and blue, ignition on-orange and green 19. Light Switch : sidelights-green and yellow, full lights-green and yellow-green and yellow black 20. Dimmer Switch : low beam-black and yellow/black, high beam-white and yellow/black 22. Horn Push Button : grey and blue 25. Direction Indicator Switch : left=blue/black and light blue, right=blue/black and red 26. Start Push Button : yellow/green and yellow/red WARNING LIGHTS 24. Low Fuel Warning Light : orange/black and green 28. High Beam Warning Light : blue and white 29. Direction Indicator Warning Light : red and light blue 35. 2 Stroke Oil Reserve Warning Light : blue and violet worked it out for him over msn heres what i worked out
can anyone else verify that the high beam and oil signal lights on the sr loom run off the same blue wire ???
ok for the oil light, you should have a connector block with Green, Violet, light blue, Red, Yellow, and an empty 1 Do you have that connector? you didnt pull the whole harness to peices right?
we solved it last nyt mate but he cut all the plugs of so hes just got wires i worked out that the blue wire needed to be split for low oil warning light and high beam warning light should be good when hes done it all
