ok i brought a 125 engine with a 180 head and piston 25 ml carb and and staned pipe and the loom.So i put the loom on the the frame and it all work ok exceped from the rear lights and and the oil light dont work as the plug that gose into the tank that tell u that the oil is low wont reached and on the throttle were u take the slack up on th cable sum times a little spark shout out i took the hole loom apart and checked for and spilt wire and i found a few so i put black tape round them but its still making sparks from the throttle and the electric start dont work sum 1 help pleases it driving me made cheers lol
it'll take them a good 5 hours if they know the electrics, most places are about £30 ph + consumables looking at £200+
wat to wire a loom 200 fu*k that it would be easy to get a diagram and last time i got a loom done from the man he wired me a loom as the old one was fucked and he took the cheepo alarm of and a new battere and that only cost a 100 cheers for the advise any way
the lights arnt working because the oil sender unit isnt plugged in and this feeds the power to the lights. plug it in or just patch the 2 colourd wires to an earth then unplug the one that makes the oil light (ones lights ones oil light obv)
