will a kx60 kx80 carb fit runner fxr180???????
Discussion in 'Maxiscooter Tuning' started by billybigspuds, May 23, 2011.
  1. billybigspuds
    billybigspuds New Member
    will a kx60 kx80 carb fit a gilera runner fxr180.
    even if i set the carb with same size jet as runner 180.
    im just after a cheaper way round gettng a manual choke carb rather than spending £170 on one
    im proberly sounding like a dum s**t here but any info will be decent
  2. tErr0
    £170?! It's about £75 for a Dellorto 25mm carb.
    The carbs aren't similar at all but depending on what size it is you could get it to work. It would be a pain in the arse to setup however as you would probably have to change all the jets, needles, etc. Much simpler to buy a carb that's more suited.
  3. billybigspuds
  4. lshigham
    lshigham Member
  5. tErr0
    25mm carb = £75
    http://www.scooter-center.com/scoweb/pages/productdetail.grid?product=288621644825520
    Manifold either £17 or £13 depending on if you want straight or angled.
    http://www.scooter-center.com/scoweb/pages/productdetail.grid?product=288621640249200
    http://www.scooter-center.com/scoweb/pages/productdetail.grid?product=288621640249712
    The difference between the very expensive carbs and these are most carbs are premix so you have to mod in an oil feed but that's a very easy job. It's actually a very good idea to run your bike premix anyway as the oil pumps love to fail.
