Wierd bogging backfire?
Discussion in 'The Workshop' started by canis_lupis, Sep 25, 2011.
  1. canis_lupis
    canis_lupis New Member
    Hi if youve read the subject then thats the best I can name the problem, it goes something like this...as most of do I ride my aerox 100 at WOT most of the time but when I let off for a courner or a junction or something then try to wind the throttle on again the scoot starts to bog down until I open up the throttle full again, then it backfires and carries on as normal, if I hold the throttle at say half then it boggs for about 5-10 secs then eventually starts to run normally for this throttle setting, ive cleaned out the carb which is the standard TK 16mm job running 85 main jet and standard airbox, its really annoying and it makes higher speed cornering interesting when you cant roll on the throttle properly, any ideas? Thanks in advance!
  2. canis_lupis
    I now suspect it might be the reeds at fault, what do you guys think?
  3. canis_lupis
    Its not the reeds, now starting to think the carb needle and tube are both worn and therfore too rich at all throttle openings except WOT, will keep this post informed.
