wider wristpin bearing?
Discussion in 'Scooter Tuning' started by 2fast4u, Oct 20, 2017.
  1. 2fast4u
    2fast4u New Member
    fresh member on the forum, english is not my main language so forgive me if i cant spell properly ^^
    i recently rebuilt my aerox engine, and after installing the 70cc piston on the new crank i noticed that my wristpin bearing (12x17x15) have 4~mm side to side play. and since this kit will run high rpmĀ“s i cant imagine this being a good thing. the widest bearing i can find is 16mm wide, but will that solve the issue?
  2. MARSH
    Early Lambretta's used shim washers at the little end to stop side-side play, I suppose you could try the same thing making some light weight washers? ID is 12mm (wrist pin) ? so OD could be 14mm? Worth a thought!
