Why's it running so bad?
Discussion in 'The Workshop' started by Ro8bieg, Jan 14, 2009.
  1. Ro8bieg
    Ro8bieg New Member
    I've just had a polini sport kit fitted and it has an 88 jet in but its running shit.
    It runs okay for about 2-3 minutes then slowly starts to loose power then cuts out. Then I have to wait for about 5 minutes until I can start it again, it just keeps doing this.
    Anyone got any ideas of what it could be?
    Thanks, Robbie
  2. Mehmet
    Mehmet Active Member
    AUDI A3
    Compression loss :confused:
    Jet size is toooo big tho
    Guessing its on a aerox?
  3. alperin
    alperin Active Member
    aerox 180cc
    ne alakaa?
  4. Mehmet
    AUDI A3
    Because i can remember this guy showing pictures of his bike and as much as i can remeber its a black aerox.
    THATS WHATS HOOD
  5. Ro8bieg
    Ro8bieg New Member
    nah was close tho, its a red aerox :p
    The spec is:
    Polini sport 70
    Leo vince tt
    Polini reeds
    Polini speed control variator kit
    88 jet
    Snorkel removed from airbox
    Just been to kickstart in blackpool and they seem to think its either starting to sieze or thers just a fuel blockage some were.
    They seem to think its using the fuel in the float then when it stops after about 5 mins or so it fills back up then its set to go again for another 5?
  6. MiNoR cOnFuSiOn
    well do yourself a fav and just dont go back there... check all your pipes are on, the coolant is blead, there are no loose fitting bits, obvious air leeks.. check the choke., set the carb up correctly
  7. Jamie
    I know minor probabally wont agree. but if it was me id strip it all completely, RE_DO it all checking gaskets seals etc...plus you get a look at the piston/barrell for any damage...research and work out exactly what the jet size should be, get that size plus 2 above and 2 under
    ive always found starting again is longer but always works.
  8. Jamie
    oh and my bad. check ALL the carb settings, idle mix, etc, check transmission for anything suspicious, broken springs yadayada
    if something goes wrong after fitting a new topend. its best to check EVERYTHING
  9. MiNoR cOnFuSiOn
    if you fitted it yourself do as james said, start again... if somohne elkse did it, take it back
  10. Blue dwarf
    Blue dwarf New Member
    A theory:
    It`s jetted too weak, runs fine when the auto choke is on..engine warms up the auto choke turns off and it dies...cools down the choke switches on and it`ll run again.
    Just a theory :)
    Oh float height on std carbs is non-adjustable unless you change the float wieght so bowl draining is un-likely.
    Tank venting could be an issue..drill a hole in your filler cap :)
