why does this happen??
Discussion in 'The Workshop' started by haz_666, May 9, 2007.
  1. haz_666
    haz_666 Member
    Its happened the last couple of days and i think its gettin worse. I will be riding along normally then if i slow down and try to accelerate i wont get any power and the bike wont attempt to get going for about 20seconds until it starts to gradualy get faster?!?!
    Any ideas??
    Cheers :tup:
  2. haz_666
    haz_666 Member
    anyone ????
    :unsure:
  3. wobbly_trials
    maybe it dosnt like you
    does the motor feel tight and does the engine note change?
  4. Major Rel14b1lty
    Major Rel14b1lty New Member
    id say it was boggin cause of to much fuel but if it only happend in last couple of days, u dont live far from me at all, what does your bike look like
  5. haz_666
    haz_666 Member
    no it jst feels like the engine cant b bothered to move and sounds like im not revining it much?!?! any thoughts??
    Gt a black n white runner.... only jst started riding it tho... i jst added u major.
    cheers
  6. wobbly_trials
    sounds like a lack of top end compression, p+r i think
  7. MiNoR cOnFuSiOn
    or belt/roller wear.
  8. haz_666
    haz_666 Member
    wel i dont think it will be the rollers or belt as they are fairly newish
    what do you mean... and how could i solve this????
    Cheers
  9. tweak
    tweak Member
    new piston and rings kit required, the current match is tired, whats the mileage?
  10. haz_666
    haz_666 Member
    I dnt know as it was disconnected but its a 51 plate?!?!?!
    How much will that cost me then???
    Cheers
  11. haz_666
    haz_666 Member
    is this what you mean...??
    www.scooter-attack.com
    article number... MF20.14008
    should i be gettin this??
    Cheers
  12. haz_666
    haz_666 Member
    Things i did today...
    Read through my haynes manual and did what i understood of it...
    1. looked at my spark plug and its a dark coaly colour (bad fuel/air mix)
    2. Cleaned air filter
    3. checked for holds in manifolds etc.... found nothing wrong
    4. set my idle to the 2 1/4 turns it should be
    STILL NO CHANGE!!!!
    I did notice however that some small air bubbles were going through the petrol pipe and into the carb.... ?!?!?!
    so people... whats rong with it??? lol
  13. wobbly_trials
    you have a lack of compression IMO but cant tell for sure without loking, could be a crank seal or crap in the carb still
  14. haz_666
    haz_666 Member
    well ive cleaned my carb and found my main jet had started to go slightly green?!?! It looks like rust... so i cleaned it which had made it a lil better, but im still nt gettin the same performance as before it went rong....do you think i should get a new jet??
    As for the compression... do i need new piston rings or the whole unit???
    Cheers
  15. MiNoR cOnFuSiOn
  16. haz_666
    haz_666 Member
    will a piaggio nrg belt fit my runner then cos ive gt one of them???
    Cheers
  17. skuzzy
    skuzzy New Member
    hey, first thing i would do is to replace the rollers and belt, as if they are worn then they will have flat spots on then which will stop them rotating. try checking or changing the torque sprint behind the clutch as if hi milege bike then could be tired,
    if u have stronger spring then once u shut off the throttle it will return the torque driver to start position so wen u go back on the throttle will let u have the same power as wen you forst set off.
    hope u understand that and its any help??
  18. capri dave
    capri dave Active Member
    The exact symptoms happened to me a couple of years back..
    exactly like you just explained it..
    The shaft that the variator fits onto had for some reason a bit of surface rust on it...
    which meant the variator would stick....(it couldnt slide open or closed freely)
    I carefully rubbed all the rust off with wet n dry and put a light oil on and its been fine since ;)
    Failing that i agree with minor...deffo sounds transmission related :D
