White smoke and air
Discussion in 'The Workshop' started by CA Zip tuning, Apr 4, 2012.
  1. CA Zip tuning
    CA Zip tuning Member
    my air filter fell off this morning when i was trying too take my carb off. I put everything back on and now white smoke is coming out of the exhaust and i can feel air around where the throttle cable is. Dont no what to do or what the problem may be. Everything is tightened i think i did double check please help thanks
  2. ramo
    ramo GoldMember
    I take it it was fine before?
    Spray WD40 over the carb and hoses ect if it affects the engine you have a leak
  3. CA Zip tuning
    yh it was fine before ? I dont possibly understand how it can just fuck up like that. I know i have an oil leak where it connects the oil tank cas tiny and i mean tiny bits of oil are dripping down about a 1/5th of a cup a day and dripping onto my crank case
  4. CA Zip tuning
    someone help ! ?
  5. Jonnymarrw00t
    Piaggio Zip 05 plate
    You need to fix that leak. White smoke generally means it's fine unless there's loads that means to much oil.
  6. CA Zip tuning
    how do i fix that leak ?
  7. Jonnymarrw00t
    New pipe.
  8. CA Zip tuning
    fuck me is it alright to ride now tho ?
  9. Jonnymarrw00t
    I'd wait till you put your airbox on tbh.
  10. CA Zip tuning
    yh my mates doing my jets and putting my air box on tomorrow duno what to say to him about the white smoke and air by my throttle cable ??
  11. Jonnymarrw00t
    Do them one by one. Jet first then check everything else.
  12. CA Zip tuning
    ok mate do u suggest i get petrol before i do jetting its low on petrol at the minute
  13. Jonnymarrw00t
    Don't really matter.
  14. CA Zip tuning
    I already have a litle metal clip which will help it stay on the carb and whats that other bit about the mounts ?
  15. Jonnymarrw00t
    they'res like a thick round triangle on your engine cases, Those to hoops push over them.
