whistling engine
Discussion in 'The Workshop' started by skatergod, May 8, 2007.
  1. skatergod
    skatergod New Member
    right as i was pushing my bike back wards 2day i could here a slight whistling from the engine... anyides??? nothing bad i hope??
  2. Nrg-Sam
    Nrg-Sam Active Member
    have you let the bike out of your sight? someone may have fitted a turbo without you knowing? :w00t:
  3. wobbly_trials
    was it running? did it only do it when you were pushing it backwards?
    more than likely clutch or brake dust, nothing to worry about, it could possibly be an output shaft bearing, slightly bigger job but no real problem to change.
  4. skatergod
    yes mate engine was turned of... just rolled it back wards...
  5. wobbly_trials
    probably the brake or clutch, wouldnt worry.
  6. Kieran
    Kieran Active Member
    st
    or some girls were behind you xD
  7. bEN
    bEN Active Member
    Ducati 848
    i hope this won't be a 'cursed typhoon' :msn1:
  8. MiNoR cOnFuSiOn
    if it does it in both directions its probably the imput shaft bearing (smaller and higher rpm than the output so usually goes first) if however its only when wheeld backwards id also say clutch related.. check the whole thing for snapped springs/contra spring length, torque driver pins/seals an mnake sure its greased.
  9. skatergod
    hmmm need wobbly down here lol think the whole engine might need a good greasing but yeh its only when i reverse it... altho when my bike goes forward... when the bike isnt turned on it makes a weired like sound like a remote control being moved when its not turned on.... :msn1: if that makes any sence at all.... just thought it was weired.. but it only does it when it goes fast when its not tunred on like when we have down hill races with the engines of lol
  10. MiNoR cOnFuSiOn
    erm, here in the south remote controls have been silent for years... u northerners are so behind :D
  11. skatergod
    we are not northerners, we are midlanders!!!!! :bird:
  12. MiNoR cOnFuSiOn
    past milton keynes./.. north half of england ;) LOOOOOOL
    (grab an atlas and a ruler)
  13. JakeSP
    JakeSP New Member
    My remotes dont make any funny noises :emb:
    My old remote control cars, Now thats a different story ;)
  14. skatergod
    lol joker thats what i ment, must have missed the word car out :bird:
  15. wobbly_trials
    sounds like your electric start mechanism is sticking.
  16. MiNoR cOnFuSiOn
    good point.. take out the pinion and twist it so it opens.. then squirt grease with a small peadactric serynge inside.. it should spin out and snap back if you flick it left to right by hand. also put a tiny bit of grease on the pins that sit in the engine/tranny cover
