which one do i need??
Discussion in 'The Workshop' started by Edgar, Jan 7, 2012.
  1. Edgar
    Edgar Active Member
  2. Edgar
    Edgar Active Member
  3. tErr0
    Order from a spare parts supplier or a dealer not a shit tuning company. They will be able to point you towards the right part or have a exploded parts diagram so you can pick the part.
  4. Edgar
    Edgar Active Member
    ok, thanks
  5. gulliver
    gulliver Member
    its the one the shaft goes thru but if u got money replace as many as u can afford starting with the shafts 2 (one the shaft goes thru and the other in engine casing that shaft sits in ) then rear drive shaft ones and others if funds available
