Which is better?
Discussion in 'General Scooter Discussion' started by AeroxSteve, Feb 23, 2014.
  1. AeroxSteve
    AeroxSteve Rox rider
    Yasuni c16 or c20, there is someone near me selling a c20 £70
  2. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    For a S6 Sport pro ? 20 for racing, but 16 for road use. The C 20 is a 14,000 rpm hooligan.
    With a stock crank - it's too much. Far too much.
  3. AeroxSteve
    Yeah for road use, I haven't got my 70cc kit yet but seeing as it's £180 new £70 was a good deal, could I just keep my s6 rep exhaust when I get the 70 put on?
    I'm not going to run my stock crank my bikes done over 20,000 miles maybe even 30 lol only about a month left till I upgrade everything though
  4. turbovetto
    tweaked ovetto
    70 is indeed a good deal - but you would need a strong crank, at least a stage 6 sport pro cylinder and a 21 mm carb. You'd need a box of jets from 90 to 130 and you'd need to remove the snorkel from the air box. You'd also need a significant quantity of rollers, very probably a Top perf transmission case with needle bearings, at least a Malossi Multivar variator and a decent clutch.
    You would need to be able to set that little lot up - and you would need to live somewhere where there were no police- because whatever silencer you put on it, it would make a helluva lot of noise.
    Are you ready for all that? I actually have an engine like that and, yes, it's fun. But it's a lot of hassle. Yes, it´s insanely fast. But for every day use I quickly get tired of it and put the stage6 with the yas R back on.
    i have seen the graph of the sport pro with the Yas 20 and it's definitely a beast. But at 14000 rpm. And that requires a lot of attention.
  5. AeroxSteve
  6. turbovetto
    tweaked ovetto
    The streetrace is a cast iron kit. it will not rev high enough for the C 20.
  7. AeroxSteve
    Yeah I'll save my money and keep my s6 pipe, cheers for the info mate
