Hi Working on a s reg yamaha neos yn50. I want to run the headlights direct off the battery to rid of dimming and getting brightwe with revs... Currently my charging system only works when lights are manually turned on. Its been suggested that i disconnect the original live feed fo switch and connect it back into the charging system so the bike thinks the lights are on and the charging sytem works, hence then the headlights being connected to battery. Where do i re connect the live wire? To the same colour wire on the R/R? Thanks in advance
