Where do all the wires go?
Discussion in 'Newbie Scooter Tuning' started by Buzz, Aug 27, 2014.
  1. Buzz
    Buzz Active Member
    Basic question.....I,m working on checking my wiring harness, cleaning, checking etc and realised that I have connector blocks with more wires in than coming out? For example I have 7 wires going into a male spaded block with only 5 coming out of the female mating block. This appears fairly common but can someone please explain why? I thought that all wires must connect to all others somehow, clearly not!?!
    The reason this matters is because corrosion has damaged one wire spade so i,m going to connect that wire to its opposite pairing with an external spade of its own , outside of the harness connector block.
  2. Merlin
    Merlin Old School Biker
    2007 TKR WRC 50
    It's simple. Some wires feed front and rear lights to the light switch, indicators on either side of the bike to the indicator switch, brake light circuits to each brake lever and common earth circuits. It's logical to connect them together when they work together.
  3. Stevep
  4. Buzz
    Buzz Active Member
    Thanks guys i,ll get new connectors and stop worrying about the odd wires not going anywhere!
