hello i have a malaguti f15 AC 2006 setup is : Stage 6 sport pro 70cc kit malossi replica clutch with http://www.donotlink-pedstop.co.uk/p/Polini_compression_spring_with_Evo_slider_–_Minarelli_–_38mm-3402.aspx and http://www.donotlink-pedstop.co.uk/...et_for_Minarelli_engines_from_1997_-2686.aspx standard variator 4.5g rollers upjetted carb malossi air filter leo vince ZX exhaust i have the yellow polini clutch springs in at the minuite the bike is fast but i want it to lift a little for wheelies lol donotlink pedstop told me to get the polini springs and polini torque spring any ideas what setup i will need? thanks
it wont let me use the links but i have Polini Compression Spring - Evo Slider Minarelli - 3.8mm spring width Polini Clutch Spring Kit Product code: AD/245.012 on donotlink
you want to set the bike up for acceleration, over speed, light rollers and set your clutch up so it bites at the start of your power band,
keep the 4g rollers, order either 1: stiffer springs for you current clutch, although i will find your clutch will ware out faster, or 2: buy a better clutch thats ajustable so u can set it to bite when u want but tbh, its more to do with you than your bike, theres people here that can most likely wheelie a restricted 50.
