What's wrong with my zip :,( help!
Discussion in 'The Workshop' started by bennyboyracer, Jan 5, 2012.
  1. bennyboyracer
    bennyboyracer Member
    PIaggio Zip 2t
    Was running well with a Leo vince tt, 17.5mm dellorto carb,5.5g rollers and a polini evo belt - jet 62
    My rather optimistic speedo was indicating 65 and then a loud hum and it cut out. Managed to get it started off electric but kick seemed useless and cuts out constantly. Could I have fucked the piston and barrel?
  2. alexmilsom95
    alexmilsom95 New Member
    Compression test is the only real way to tell!
    Also, what do you mean the kick seems useless?
  3. ramo
    ramo GoldMember
    easily could have lol
    take off the barrel firstly and have a look its the best way to know what youre dealing with... any of the pipes on the carb ect loose? elec start can easily turn a small heat sieze into a dead barrel..not advised. was it easy to kick over?
  4. Jonnymarrw00t
    Piaggio Zip 05 plate
    Don't see how this has killed your zip :/ I ran same setup for a year. Pull the bore off and check it all out.
  5. bennyboyracer
    PIaggio Zip 2t
    Will it be obvious what the problem is once the barrel is off? Also what is the easiest way to get to the barrel, from beneath the bike if raised up?
  6. Jonnymarrw00t
    Just unbolt the engine. zips are fucking vile to pull heads off in the bike. you'll see scored in the piston or bore if there's any damage.
  7. bennyboyracer
    PIaggio Zip 2t
    So the whole engine has to come out?
  8. bennyboyracer
    PIaggio Zip 2t
    Something else, found a tool in a bag labeled 'zip' is like a tree shape, is this a variator locking tool. If so how do you use them?
  9. Jonnymarrw00t
    It can be done by just taking the exhaust/ pannels off but it's very hard and you'll end up smashing it up like me haha. It's not a very hard/long job to drop the engines.
  10. Jonnymarrw00t
    I wouldn't know mine never came with one, Can you take a picture of it ?
  11. bennyboyracer
    PIaggio Zip 2t
    Seem to have lost the tool :/
    Also my variator clips have come off/ fell out where do they go ?
  12. bennyboyracer
    PIaggio Zip 2t
    Oh and by the way I am contemplating a 70barrel will this setup be reliable with a 70 quid kit attached ?
  13. bennyboyracer
    PIaggio Zip 2t
    It feels like kickstart is not attatched properly
  14. murerg
    murerg MBK Hero!!!
    The clips that hold the variator?... hmmm... that does not sound good... If not in place the variator will not open correctly... Wouldnt recommend you driving without them on.
  15. bennyboyracer
    PIaggio Zip 2t
    Can't drive anyway as I live on jersey and all parts have to come by post and takes a while
    Do you think the variator clips could be the issue ?
  16. Jonnymarrw00t
    are they like little triangle bits ? if so pull your variator apart they clip onto the back plate of the variator and I wouldn't ever buy a cheap 70's.
