whats the best grease for throttle cable? please
Discussion in 'General Scooter Discussion' started by ludixblaster, Dec 6, 2008.
  1. ludixblaster
    ludixblaster Member
    gilera runner 125sp
    thanks alot
    Would good old wd40 do the job?
  2. capri dave
    capri dave Active Member
    WD40 is good for freeing off sticky cables, but the problem is it dont stick around long...
    see if your dads got some car engine oil in the shed, the thicker the better ;)
  3. Kieran
    Kieran Active Member
    st
    I always thought thicker oil was worser?
  4. ludixblaster
    ludixblaster Member
    gilera runner 125sp
    ok so just put some on either end of the cable. where it goes into carb and joins twist grip
  5. ludixblaster
    ludixblaster Member
    gilera runner 125sp
  6. Burns
    Burns Active Member
    Aprilia sr50
    used engine oil :)
  7. capri dave
    would be better than nothing...
    but you just want a nice thickish lubricating oil, that dont just run all the way down and out the other end, leaving the cable dry...hence why i said thicker the better ;)
    And the correct way is to disconnect one end of the cable and pour the oil down it...
    just lubricating the ends wont achieve anything!!
  8. Burns
    Burns Active Member
    Aprilia sr50
    similar to what i normally do with cables, i dip the end then pull the cable through and back down then dip again and so on and so on
  9. WOLFFY
    WOLFFY New Member
    Axle grease?? lololol
  10. DYS VTR
    DYS VTR New Member
    skanky cRaKwhoR3s
    seamen
