I have a 2000 neos with geneli exhuast witch was on before I got the bike It's also has a brembo from brake with braid hose I just took the washer out the veriator lol
MZ TS125, K&N filter & race exhaust with next to no baffles in it, and all with the shittest brakes imaginable.
Aprilia Sr Factory, Malossi Sport 70cc (ported) and also all engine block ported, Motoforce 15k RPM crankshaft, Giannelli Shot V4, 21 Dellorto Racing Carb, Malossi Vl13 Reed valve, Malossi straight inlet, Malossi air filter, MHR variator, MHR X-Kevlar, Polini 3G clutch, MHR clutch bell.
'06 Sym 250 '96 Yamaha 600 and enough experience and sense to know that if you don't match your brakes' performance to your speed capability you are a selfish and inconsiderate danger to other people
Why would I want to do that? I haven't got one. If anyone has they might start here: http://www.wemoto.com/bikes/mz_-_muz/ts_125cc/73-85/ Joking apart Burridge, take care - I had a bike with much more going power than stopping power nearly 40 years ago, and I live every day with stronger painkillers than most people ever see, as the result of hitting a stationary ford capri at about 75mph. Fortunately no one was hurt but me - but I could have killed people.
I understand where you're coming from, I have to plan ahead with braking alot more than I should, the only way of improving the brakes on my bike is to source an entire front end from a later disc brake model MZ, and they're as rare as rocking horse shit unless you want to pay over the odds. Instead, I made a longer and stronger brake lever arm and put it on the outside of the drum as apposed to inside the drum like it is originally, but the braking is still fairly poo.
Currently, ovetto malossi team 2 Doppler crank flowed cases VL 14 reed box RSE wedge Stage 6admission wedge Oko 28 mm carb Malossi internal rotor digital advance ignition Yasuni Carrera 30 black edition pipe Nitro water pump Malossi overange pack Malossi gear up kit Top perf gear box plate with needle bearings radiator from a derbi & radiator from a Nitro Aprillia SR 5 spoke wheels lowered stiffer forks conti oleopneumatic rear shock (240 mm - low) Malossi drum pads (rear) Stage 6 Oversize front disc Michelin Pilot Sport rubber Stage 6 long throw stem STR8 flat bars Domino quik-draw throttle
And the oveto was 100 at the start ?? The bike ment to be same as my neos so how fast you getting out if that and how much did it cost
I have a 2007 Peugeot TKR 50cc 307 WRC Rally Victories Edition, with a Polini variator, Athena Kevlar belt, 5.5 gram rollers and a Technigas sports exhaust and it's currently in bits, having some porting work done to it, before I set it up and jet it up properly. I'm also changing the off-road tyres to road tyres, for improved road handling. as the block tread ones make the handling 'interesting' in the wet and not in a good way. I've fitted the Mk 1 Trekker headlamp (much better than those poxy later jobs, with focal lenses, they are crap), I'm converting the bike to three stage lights (sidelights, dip beam and a proper 55w main beam) using a mix and match of Peugeot scooter switchgear and adding a number plate light. If I get pulled over then, it's fully compliant with motorcycle requirements, so they can do diddly squat about saying it's not legal. When I've got more cash, I want to get a replacement set of TNT body panels and change the paint job to something a bit more tasteful, but still using a standard Peugeot red paint colour, as Torero Red seems to be really hard to get hold of and the rally stickers don't exactly float my boat as I'm 51, not 17. I'll get a local vinyl sticker shop to make up some TKR stickers but I'll leave all of the advertising ones off. @ Burridge Keep da drum brake, blud; dem biyatches pure luv dem drums on da MZs, aii.
I've got two sets of road tyres here that I'll use up first, then I'll get a set of those as the stats on those tyres look really good. There's no way I'm fitting Ying Tong Ditchfinders to my pride and joy.
