after a few discussions with other members and looking at all the 70cc kits,cranks,clutches and exhausts you can buy for 50cc scooters iam interested what everyone's wish list would be for a performance engine.
This is going for a yamaha aerox with a minarelli engine Cylinder stage 6 sport pro mk2 70cc https://www.scooter-attack.com/shop...6602-Cylinder-Stage6-Sport-Pro-MkII-70cc.html Crankshaft stage6 HPC https://www.scooter-attack.com/shop.../Midrace/S68016600-Crankshaft-Stage6-HPC.html LeoVince HandmadeZX Chrome Exhaust https://www.scooter-attack.com/shop...madeZX-Chrome-Exhaust-with-euro-approval.html Carburettor Stage6 MK 2 Dellorto Black edition 19mm ( main jet 92, pilot jet 50, needW7) i have the 21mm version of this carb and its very very good https://www.scooter-attack.com/shop...-19mm-main-jet-92-pilot-jet-50-needle-W7.html Uni Pod Filter Foam Pod http://www.ebay.com.au/itm/UNI-FILT..._Parts_Accessories&hash=item43a85dba69&_uhb=1 Malossi Variator https://www.scooter-attack.com/shop...999/CVTs/Sport/M517075--Multivar-Malossi.html Malossi Fly Clutch (107mm) https://www.scooter-attack.com/shop...s/Sport/M529450-Malossi-Fly-Clutch-107mm.html Malossi Clutch Spring Kit For Fly and Delta Clutch https://www.scooter-attack.com/shop...6-Clutch-Spring-Kit-Fly-und-Delta-Clutch.html CDI Malossi Without Immobilisers https://www.scooter-attack.com/shop...M558133-CDI-Malossi-Without-Immobilisers.html I dunno if you mean this flywheel, Flywheel Disc for Internal Rotor Ignition https://www.scooter-attack.com/shop...lywheel-Disc-for-Internal-Rotor-Ignition.html Total Cost is around 640 euros
Because the stage 6 70cc kit is aluminium compared to the malossi sport and polini sport also a tad cheaper The exhaust could be upgraded with a yasuni r or something but a leo vince zx is much cheaper and does the same job pretty much
Bidalot 94 cc Pack http://www.maxiscoot.com/bidalot-pa...na-horizontal-lc-nitro-aerox-bid10500912.html Bidalot/PVL ignition http://www.maxiscoot.com/bidalot-allumage-a-rotor-interne-digital-factory-2011-bid14000810.html Bidalot Exhaust http://www.maxiscoot.com/bidalot-ec...factory-2012-mbk-nitro-aerox-bid15000912.html and all the usual trimmings ! One day..... one day........
Well it's pretty much what I'm using now - Malossi gear up kit Top Perf gear case Polini Transmission case with bearing & nut (only because I have a Minarelli engine - it's a piece of shit but it has the bearing for the transmission shaft - and that alone justifies the hassle). Malossi Overrange pack Polini or Malossi clutch RSE racing reed box wedge Stage 6 RT admission pipe DelOrto VHST 28 or Oko 28 carb Stiffer lowered suspension front & back Oversize disc on the front. What I'd really like is to send the whole thing off to RSE Racing for a complete strip/rebuild using his expertise on the engine. Port timing, volumes, squitch etc. He regularly gets over 20 horses (on his 'conservative' dyno) from 70 cc cylinders. He measures everything & machines everything to get the optimal performance out of whatever he is given. If (when) I put the Bidalot Crank in there with the big bore kit, I'm going to do it. In a sense - the set up is more important than the actual parts.
