What would happen?
Discussion in 'Maxiscooter Tuning' started by braindamage, Oct 9, 2011.
  1. braindamage
    braindamage Member
    172 PIAGGIO TYPHOON
    I am trying to buy a few sets of rollers from scooter center and 1 the 13g are 20x17 and the 12.5 are 19x17.What would happen if i was to mix the two sets seeing that the have two different diamentions ? :confused:cratch:
  2. u33db
    u33db Member
    Several Bikes
    If one is bigger than the standard size they won't fit on the variator.
    If one is smaller than the standard size they'll rattle like f#@k and won't help in any way.
    Buy the correct size for your bike.
  3. stkflote
    stkflote Member
    zip 2t cat
    you can mix rollers most rollers are all same size ,just different weights
  4. nrgandy
    nrgandy New Member
    the 20mm ones are 180 ones i belive. keep to stock size unless your transmition is setup as a 180. 13g should be ok.
