WHAT WOULD CAUSE THIS TO HAPPEN
Discussion in 'The Workshop' started by mazhead, Aug 4, 2019.
  1. mazhead
    mazhead New Member
    Hi
    I wondered if someone new what would have been the cause of the damage regarding the picture attached. Sparkplug hook bit was missing too!
    Thanks
    Maz (no idea about anything)
  2. MARSH
    Running way to hot ?
  3. Stevep
    Pre-ignition, plugs too close to the piston crown, too hot, valve stem failure.
    Complete engine strip and rebuild, (to fish out the remainder of the piston from inside the engine) new piston/barrel kit, new cylinder head,
    full gasket set, oil and filter change.
    Best check the cam chain guides as well for damage while you're in there, and the oil pump
  4. scubabiker
    As Steve says.
    Ran too hot or without enough oil.
    I'm putting money on it being not enough oil, or really old oil.
    Could also have been the cam chain or tensioner, but it looks for sure that it's run hot.
  5. Oletimer
    Oletimer New Member
    Piaggio MP3 250
    I'd go for the cam chain as a first port of call, but you didn't give any pre breakdown symptoms: ie: noises, vibrations, was it smoking etc...
  6. Stevep
    I'd have to dis-agree with the above comment. Not completely though......it is still a part I would check, just not straight away.
    The reason being, if you look closely at the piston crown, or whats left of it, you can see that it has started to melt before it broke up. This would indicate very hot running plus pre-ignition.
