What to do?
Discussion in 'The Workshop' started by billy_sr, Sep 2, 2009.
  1. billy_sr
    billy_sr New Member
    basically my belt shredded, I got the clutch nut off, but variator one won't budge, is there anyway I can get it off without an impact drill? Or get the belt on ?
  2. MiNoR cOnFuSiOn
    yes.. take the oil pump out... once this is out the starter pinion will come out and you can JUST get the belt in..
    why are you doing a belt wihtout an impact wrench to hand? :confused: seems a little silly to jump into a job knowing you dont have the tools to complete it.
  3. billy_sr
    billy_sr New Member
    Well on other bikes iv had you can jam a screwdrver in and undo it, and this is on a runner 125sp, so I'll remove the the oil pump and the starter pinion and should just pop out ye?
  4. Stig
    Stig Well-Known Member
    EXUP1000
    I usually find that when a belt shreads it winds everything up around the rear of the variator and the pump...so you have to take everything off anyway to clear it out
  5. Rick-UK
    Rick-UK New Member
    Runner 200
    Even if you get the variator undone I wouldn't trust a hand-tightened variator
    And to make it easier to get the new belt on, put it round the clutch then squeeze it around the clutch so there is more slack to get it over the variator side :good: I was pissing about with mine for about 15mins until I thought of that, then it was a piece of piss :rolleyes:
  6. MiNoR cOnFuSiOn
    you mean you can bodge the fuck out of it risking the bearings the straightness of the crank and the casing as your basicly prying 52nm THROUGH your starter pinion and sideways on the crank...
    just for the record.. never do this.. its pikey mechanics and the reason cases crack/cranks bend and generally POOR workshop practice..
    a locker is 6 quid, an impact wrench is a score.. dont be tight
  7. LEE
    LEE Member
    also if your running autolube i always change the oil pum belt aswell better to be safe then sorry for the sake of a quid belt
  8. billy_sr
    billy_sr New Member
    btw I have brought a impact drill but wouldn't budge it ! I'll give the otherway a shot if not I'll get the garage to pick it up.
  9. monty9120
    monty9120 Active Member
    Vespa gts300
    the belt gets everywhere so the whole lot needs to come off
    change the oil pump belt and check the main cog. check the key slot in the middle if this is wearing circular replace it. your water pump runs off this and they wear out
  10. billy_sr
    billy_sr New Member
    I'll check it out tomorow when I pick up the bike tomorow and decide what I'm gonna do then..
  11. MiNoR cOnFuSiOn
    impact drill is shite... just go get a score imnpact wrench from argos.. you WILL use it millions of times
  12. Rick-UK
    Rick-UK New Member
    Runner 200
    Yep I got an Argos one, they're double the price now because they got a different logo on them though. Probably used it over 50 times in 7 months, that's without the times mates have borrowed it :rolleyes:
  13. MiNoR cOnFuSiOn
    ive used mine nearly daily for 4 years.... still go's..
