what should i get to tune my Speedfight 100 ?
Discussion in 'Maxiscooter Tuning' started by dannibaz1, Jun 13, 2010.
  1. dannibaz1
    dannibaz1 New Member
    speedfight 100
    I have brought and re-sprayed my Speedfight 100 now i need some ideas for some good tuning parts to get for my bike if you know any good ones please tell me :)
      File size:
      23.4 KB
      649
  2. capri dave
    capri dave Active Member
    i saw a dyno graph once on taffspeeds old web site showing the difference a good pipe makes on a speedfight 100...
    The difference was quite impressive, so on that info i would buy a pipe 1st :)
    Then you'll need a gear up, as the 100cc engine is very undergeared as std...
  3. dannibaz1
    speedfight 100
    Thanks i will be buying a new Exhaust when i find a good one :)
  4. wobbly_trials
    depends how far you want to go really, the best way is a piaggio 125 conversion.
    if you are sticing with the 100 lump though i would go down the pipe, gear up, bore kit, carb, variator route.
  5. Gilly Boi Mike 70
    Gilly Boi Mike 70 New Member
    Pm tuning make a couple of different exhausts for the 100 which will defo make a difference and look better than standard.
  6. capri dave
    Theres a Doppler S3R pipe for the 100cc speedfight...hell of a lot more cheaper than the pm pipes...
  7. MiNoR cOnFuSiOn
    the old "handbuilt in the uk" pm pipe for the auto's WAS just a rebadged s3r. good pipes tho, for what there ment for of course.
    ditch the bike if you want to tune somthing. the parts for these are expensive compaird to a piaggio 125 unit and the 125 starts out much faster than the tunned 100 (tunned 120's with big carbs, pipes, gear ups, blah blah are still poo compaird to a stock typh/runner/other piaggio based 125. even 50cc engines make more power than these
