hi i have been doing some project's and my first one i was pleased with coz all the carb/manifold/air filter was all tuned right and i completed this project in 4months buying bit by bit and iv now started a new one but before i go about changing engines im not to sure what engines can fit the honda x8r frame i have two one is a 70cc just need carb tuned to profection and the other one just sitting there for spare so i want to make a project out of it and stick a piaggio 125cc 2t engine that im in the middle of tuning to a 172cc i know i have to make brackets for this one but does anyone know what engines will fit the honda x8r ??? thinking of buy another honda x8r frame for another project, many thankz jamie
think its similar to a speedfight/morini engine, so mounting positions would suite a minarelli vertical (if its not actually one in there already) pretty dire tbh. anything will fit if you have a welder... probably better off dumping it and buying something the engine fits into easier, any piaggio based 2t auto bike will do can pick scoots up for pennys if you dont mind them not running. alot less work/probably cheaper than the x8r... if you have your heart set tho there are speedfight conversion kits im sure could be easily adapted... you will need more than just the engine tho. loom on the 125 is alot heavier duty as the starter requires a big battery, and the bike has to charge this. if your not bothered about an electric start you can hook the stator output to any loom prettymuch, just need the correct rectifier and adapt the rest of the wiring to suit.
thank mate im defo putting my piaggio on my x8r and i just want to know what engines will go in without much work to the x8r frame as i can get anoth one for 40 pound
and as im saying, add an hours welding labour to that and you have 100 quid... and i can get a zip for 100 quid any day of the week prettymuch, especially with a blown engine.. if your doing the work yourself its a cheap option, altho your asking v simple questions for somebody capable of welding engine mounts into a bike safely... so you will be paying someone/buying and adapting an existing conversion kit... so factor this in and decide if its worth all the messing about.. as you can do a piaggio conversion in an hour with a file and a hacksaw LOL
well i have contact and get most things cheap like the other day i got a derbi senda for nothing and i got a honda x8r just blown up head for 35 pound so im not bothered i dont wonna just by a bike and ride it i want to custom make over my own
