What rollers...
Discussion in 'Scooter Tuning' started by HitterD, Oct 7, 2007.
  1. HitterD
    HitterD New Member
    I have a SR50 2007 (carb) bike. I just purchased a Laser X Pro exhaust system for it. What size rollers should I buy to go with the upgraded pipe? Are there any other changes that I need to make after installing the pipe?
  2. haugh
    haugh New Member
    +5% upjet
    Buy a box of stage6 rollers, i would suggest 4.0 4.5 5.0 5.5 ;)
  3. capri dave
    capri dave Active Member
    its trial and error mate im afraid...you want to buy a few sets 0.5g lighter than std and a 1g lighter set...
    And TEST...TEST...TEST away!!!! only then will you know youve got the perfect weight in for YOU!!!!
    yeah someone may come on after me and say you need xg for your set up...and putting them in may be an improvement...
    but how you gonna know youve got the perfect set up without trying it 1st ;)
  4. HitterD
    HitterD New Member
    Whats 5% upjett :emb:
    edit: how will i noe when i have the right set of rollers in there?
  5. capri dave
    I use the speedo needle as a guide ;)
    And when you fit a sports pipe...you have to put a 5% bigger mainjet in...i.e..5% upjet ;)
  6. haugh
    haugh New Member
  7. HitterD
    HitterD New Member
    Well, a 2006 SR50 with Piaggio engine is supposedly equipt with 17 x 12,3 mm and the weight is 7.7 grams (on the Piaggio).
    Mines a 2007 SR50 with the piaggio engine so I am assuming theyre the same ?!!?!
    So what is the 5% upjetted sizes for those above specs?
  8. capri dave
    Those above specs are your roller weights (std)
    a 5% up jet is the main jet in your carb ;)
