does anyone know what decent reeds, if any, will fit an enki induction kit for a speedfight 50 (the one that lets you use a v reed)?
you should get some carbon fibre reeds they wiil be best and i think pm tuning sell them if not i have found them here although i think the picture is rong they come with 3 sets of different thikkness and are mallossi at £15 http://www.te-motorcyclespares.co.uk/MalossiRacingReeds.asp make sure you pick the speedfight ones :good:
you can buy sheets of reed valve material, you place your old reed ontop, trace round it and cut the new one out
ok thanks for the replies. also on shiny red tunings site it shows a reed block modification where the metal stoppers on the block are cut down, what does this do when they are cut?
it will let more fuel and air frew easyer giving u better throttle response and better crankcase charging
it could also damage your reed petals, its not an issue on piaggios, as the reeds sit nicely on the inlet port sides, but can lead to damage on different shaped cases..
thanks for the info, i didnt cut them down just to be safe but i bent the stoppers out slightly so it allows the reeds to open a bit more :grin:
