what reedblock.. mhr or evo
Discussion in 'Maxiscooter Tuning' started by monty9120, May 5, 2007.
  1. monty9120
    monty9120 Active Member
    Vespa gts300
    what will be the best reedblock to use
    im going to have a 25mm and hopefully a straight inlet manifold if not one that comes out of the side
    cheers.. im pretty sure there both the same but are the correct reeds supplied or do i have to get the seperate with either
  2. MiNoR cOnFuSiOn
    both moddled on the stock reedblock so fit the reeds/backplates out of ether and you got the same thing...
  3. monty9120
    Vespa gts300
