What main jet size do i need for my katana?
Discussion in 'General Tuning' started by katana R, Jul 10, 2010.
  1. katana R
    katana R New Member
    I have a suzuki katana LC and im not sure which size i should use as my main jet?
    My set up is
    Race crank , high quality seals and bearings , Malossi 70 bore kit, Malossi primary gear up kit , Bmg race manifold , 21mm delorto carb , unrestricted cdi unit , Malossi delta clutch (red springs), Malossi contrast spring , Polini variator 4.9 gram rollers , leo vince tt exhaust
    Thanks a lot! :)
  2. GUNS
    GUNS the usual suspect
    racing SP70 & LX172
    Did you fit all the parts yourself?
    With all the variables of parts, nobody will be able to tell you.
    I suggest you buy a jet kit and experiment, or go and have a dyno session.
  3. Spectre
    Spectre Member
    Katana-R, Runner 125
    Im running a similar setup and i think the main jet is a 72, cant remember with any certainty, as the above poster said though, you'll really only be able to get it right by expirimenting with a set of them. theres a guide on here somewhere to tell you how to do it yourself.
  4. katana R
    katana R New Member
    Thanks for the reply
    I'll but myself a set and try them out
