what jet should i use ??? help
Discussion in 'General Scooter Discussion' started by Sam Pottier, Jan 24, 2014.
  1. Sam Pottier
    Sam Pottier New Member
    i have a 139qmb engine stock 50cc stock carb and im getting 45mph on stock jet
    but i have a polini free flow filter and stage 6 exhaust on it and i need to upjet,
    im thinking about going from stock jet to #88
    i need opinions
    and before you ask I DONT KNOW THE MAIN STOCK JET SIZE,
    all i know its in the 70's
  2. scootzmadness
    how about this.........
    go read the other gazillion threads about jetting.... they may help....
  3. Sam Pottier
    i need to know if it is the same principle for my carb
  4. scootzmadness
    ITS THE SAME PRINCIPAL FOR EVERY CARB !
  5. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    All carbs are the same. They only know one thing. How much air is going through them. It's up to you to give the engine what it needs.
    - I would sell your Polini filter to some other fool, keep your original airbox - put your new pipe on and start with a 75/80 jet - and see what the plug looks like.
    Putting a sponge filter on a scoot with a standard engine is a waste of time and petrol - and it's also a good way to wreck your engine if you don't know what you're doing.
    The real issue you will have is rollers. You will need lighter ones.
    MARSH likes this.
  6. Sam Pottier
    is there anything else which i need to take note of ?
  7. turbovetto
    tweaked ovetto
