what jet do i need??
Discussion in 'General Tuning' started by Alexx8r, Jan 10, 2013.
  1. Alexx8r
    Alexx8r Member
    Honda X8R 70
    hello
    Ive got a honda x8r with a polini sport 70cc kit, leo vince tt sports exhaust, polini hi-speed variator, 6.7g rollers, malossi belt, adjustable race clutch, race cdi unit, polini reeds and standard air box with malossi filter sponge, i having trouble getting it running properly so can what size jet do i need?
    and any other help would be handy
    thanks Alex
  2. steveaerox50
    steveaerox50 aprilia owner
    1999 aprilia rs125
    what is the size of the main jet now , and are you using a standard carb or a bigger one
  3. Alexx8r
    Alexx8r Member
    Honda X8R 70
    ive got an 88 jet in it at the moment and using standard carb
  4. steveaerox50
    1999 aprilia rs125
    try a 90-92
  5. Alexx8r
    Alexx8r Member
    Honda X8R 70
    really? its running to rich
  6. steveaerox50
    1999 aprilia rs125
    oh right well if its running rich go down a few jet sizes try a 86
  7. Alexx8r
    Alexx8r Member
    Honda X8R 70
    ok thanks for ur help
  8. steveaerox50
    1999 aprilia rs125
    no worries
  9. Snake_Plissken
    Snake_Plissken New Member
    The problem your having is your using a stock air box. You either need to open the box up by adding those filter plugs or getting an open air filter. The reason your rich is you don't have enough air coming in. since you have a aftermarket exhaust you should use a open filter with a 90 main jet. You need to drop the needle clip down slot too. All this is done if you have a 17.5 to 19mm carb. 14mm is to small. I used the filter plugs cause it makes the scooter still look stock. Add 3 then see how it runs if bogs somewhat add til it don't bog anymore. Good Luck
  10. Alexx8r
    Alexx8r Member
    Honda X8R 70
    ive tired it with a open filter and still didnt run and wot are filter plugs? and what does dropping the needle down do? im gunna down jet it
  11. Mopedmania70
    Mopedmania70 Member
    Gilera Runner 70
    He seems to be answering his own questions?
    steveaerox50 likes this.
  12. steveaerox50
    1999 aprilia rs125
    dropping the needle down a notch leans out the mixture , just try a down jet and go from there , a new spark plug is always helpful as well
  13. phil.s
    phil.s Active Member
    i race pipe will lean out the mixture so taking of the stock air box will make run even leaner all you need to do is find out what the stock jet size should be then go up 10% for the pipe do this with a new plug fitted and take it for a ride and see how it is
  14. phil.s
    ohh just read your post again i forgot about the 70 kit dont forget you will need to jet for that aswell
