what is a good aftermarket exhaust for my sm50 2012 (geared)
Discussion in 'Bike Chat' started by Ethan Benbow, Oct 21, 2012.
  1. Ethan Benbow
    Ethan Benbow Member
    hi, was just wondring if anyone could tell me what a good aftermarket pipe is? and also if a upjetted 22mm carb would be okay thanks!
  2. A-LY
    A-LY Active Member
    dont bother with a 22mm on a 50, especially a geared one.
  3. Ethan Benbow
    Ethan Benbow Member
    how about a 17.5? would this still give it enough power?
  4. A-LY
    A-LY Active Member
    yea 17.5 would be good, anything bigger and you start losing airflow
  5. Ethan Benbow
    Ethan Benbow Member
    even with a after market filter?
  6. A-LY
    A-LY Active Member
    by airflow, i mean the air being pulled through the carb by the engine.
    anything over 17.5 and a 50cc cant really pull enough air through to get good flow, so you just end up with a load of slow moving air with petrol drops init.
    think of it as breathing through a range of pipes... too small and you cant breathe fully, too big and you dont get any flow through the end.
    you might get away with a 19 if you redline the bike everywhere
  7. Ethan Benbow
    Ethan Benbow Member
    okay thanks, also would brilling out the baffles add to the power!?
  8. A-LY
    A-LY Active Member
    yea, but it would be loud as foook though
  9. scubabiker
    in some 2t pipes (derbi senda, tzr 50) there is a front baffle that acts as a restrictor, take that off and see how it runs
  10. Ethan Benbow
    Ethan Benbow Member
    ok i will remove that and see how it runs! cheers.
  11. James Townsend
    James Townsend New Member
    Hey, I Have same bike.....
    Buy a Technigas Enox Exhaust and take the baffler out you'll be loving it trust :p
    scubabiker likes this.
  12. Ethan Benbow
    Ethan Benbow Member
    ok will do mate! how fast does it go!?
  13. Ethan Benbow
    Ethan Benbow Member
    just de drestricted my exhaust, changed the front sprocket to a 14tooth and im also going to change the rear sprocket also the carb has been upjetted. what is a good but cheap exhaust? and would i need to upjet again because of the new exhaust? cheers
  14. A-LY
    A-LY Active Member
    yea but only a few sizes up
