what gearing for polini 70cc cast iron?
Discussion in 'Scooter Tuning' started by bikerbeynard, Nov 28, 2011.
  1. bikerbeynard
    bikerbeynard Luke
    gpr 125 ,mbk rocket,
    Should i use primary or secondary gear up kit, for my mbk rovket minarelli vertical ,and also can you use both?
  2. tErr0
    You only need one gear up kit. The gearbox all combines to make one gear. You change the ratio of either the primary or the secondary to make the gearing longer.
    You will only need a small increase on a sport set-up.
    It's normally best to go for prepressed primary gears as it's easier to fit.
  3. GUNS
    GUNS the usual suspect
    racing SP70 & LX172
    reading you sig specs, if set up right a small gear-up ratio will give you more speed and lazy cruising. But with less spec, what tends to happen, is bike isn't too bad in picking up speed, but hit some heavy wind and unless the torque control is set up spot on, the bike becomes a slug. As said, pre-pressed primary gears can be in place and riding in. less than an hour.
    As for the whine off the straight cut gears, after 30-40, sounds like a super-charger spooling up.
  4. m1tch
    m1tch Member
    Ive just watched a video of someone swapping out gears, seems pretty simple to do and you can also check the CVT system for wear and change rollers etc whilst its all apart :)
  5. bikerbeynard
    bikerbeynard Luke
    thanks but sorry guys but my 70cc kit aint the sport just your standard ac polini cast iron,my bad:( should i still go with your advice terro
  6. tErr0
    That is the sport kit?
  7. bikerbeynard
    bikerbeynard Luke
    thanks for that terro mate, feel like a right nube now lol,any reccomendations on which brand or should i just go for the cheapest i can find.
  8. Jonnymarrw00t
    Piaggio Zip 05 plate
    stage 6 pre-pressed.
