What Do You Use To Take Off The Variator?
Discussion in 'The Workshop' started by CrazyCrisUk, Jan 21, 2008.
  1. CrazyCrisUk
    CrazyCrisUk New Member
    Title says it all, not everybody here can own an impact wrench, so I was wondering how you personally remove the variator bolt?
  2. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    call me bodgey but i used to use a impact gun but until i c what htey can do to a crank, now i use a roofers tool of some sort appartently to pull out nails or sumin will psot a pic but its pointed at the ends and sits perfectly between the pulley and the casing, its ok i neever do them over tight jsut incase dont wanna snap my casing by tryign to undo it
  3. Kieran
    Kieran Active Member
    st
    Variater locker..
  4. numanoid1704
    numanoid1704 New Member
  5. kyle1b1
    i use a pair of big water pump pliers to hold out pulley then just undo nut.
  6. midge
    midge Member
    i have an electric impact gun bought from machine mart for under £20 iirc, does it perfectly..
  7. nrgandy
    nrgandy New Member
    i used to use a cheap impact gun but i dont use it on cranks now i just use my vari locker (which i also re drilled for use with 125 engines two tools in one lol)
  8. Samuel
    Samuel New Member
    bad memory's of changing roller i used to a scudrive to lock it and sometimes it didnt work but best thing to use instead of get vary locker tool use a peg works like a charm
