What crankshaft?????? Set up?
Discussion in 'Scooter Tuning' started by antos, Sep 16, 2009.
  1. antos
    antos New Member
    Hello Guyz :)
    I own a nrgmc2 lc and i want to install a top performance cast iron kit (48mm bore) and i want you to suggest me what crankshaft do you recommend to use with the current kit?Also carb and a fine set up not anything special
    Thanks in advance :)
    Cheers :clapping:
  2. MiNoR cOnFuSiOn
    bgm if your after sommin cheap.. polini evo if you dont mind spending money. wouldent bother wiht any other aftermarket crank tbh.. ive ran many a ported ali kit on stock cranks for years (my rms is a pattern type crank, stock wiht a better bearing better conrod and thats about it, has outlasted 4 kits already and still strong)
  3. antos
    antos New Member
    Thanks for the answer minor :) The reason im repairing the whole engine is that it wont start after a heavy rain and when i removed the reedblock and put it back it everytime i hit the kickstart or the electric starter a sound like scratching something comes out...I think its the crankshaft bearings or the barrel f**Ed ...Anyway so will it be better to get stronger bearings and standard crank ?or just a bgm crank (im about to spend 100-110euros i think thats nearly 100 pounds ..so among doppler and others should i prefer bgm or the standard with better bearings? :)
  4. MiNoR cOnFuSiOn
    nope, c4's are better bearings but alot harder to fit.. i personally wont use anything but c3 steel race bearings (the c4's are plastic and a fucking pain to get a crank in without melting them) dont get me wrong, you can get a crank in just fine, i prefer to not use a hammer tho...
    so ye, stock ntn type bearings are the ones for me (just make sure there metal)
  5. antos
    antos New Member
    ok but as i checked i couldnt find any bearings c4 and crankshaft on scooterattack and scooter center :/ thanks for the help minor if you know any store providing them let me know mate :) cause im gonna order em ...
  6. SimonT
    SimonT New Member
    hey man... ive got an RMS crank in mine.. its a cheapie, but seems to be holding up.
    as for bearings... i just got a kit from scooter centre that had the seals and some SKF bearings in them... so far they are doing the trick... they have done about 6000km (round 3750mi) so far.
  7. antos
    antos New Member
    Rms crank ? never heard of that dude ...6000 are good dude :D if you can send me any links or your msn to show me the items on the shops :) i was thinking of matching top crank +top kit but if theres a better solution let me know :D
  8. SimonT
    SimonT New Member
  9. antos
    antos New Member
    Guyz i have a problem here, people say crankshafts stroke shouldbe 39mm and something about the small end diameter on the conrod ...I just want a crankshaft which can be fitted to the bike without doing anything and to fit the piston ( small end diameter)im talking about nrg mc2 lc and top performance cast iron kit . im afraid to buy any crankshaft ...If anybody knows for sure about a crankshaft thats totally fitted without any grinding or i dont know ...Just like the standard one fit and go... If u have any clue let me know please
    :amen:
    Thank you
  10. SimonT
    SimonT New Member
    im not sure about that engine, but you could always get the calipers out and measure :)
  11. antos
    antos New Member
    Mate i dont get you..What i meant was that ,i cant measure the new crankshaft since im buying it online and it doesnt mention any dimensions :/ i know my crankshafts dimensions ! :beg:
  12. SimonT
    SimonT New Member
    ohhh gotcha....
    i email questions through to the people at scooter center....
    sometimes they dont understand, but their english is pretty good.
  13. antos
    antos New Member
    Ok i'll try that mate :) thanks a lot
  14. SimonT
    SimonT New Member
    no worries...
  15. MiNoR cOnFuSiOn
    stock is 39 stroke wiht a 10mm gudgion pin.... some pistons run a 12mm pin, if you buy a 12mm pin crank they usually come wiht a down stepper bearing anyway ()meaning you can runn a 10mm piston on a 12mm conrod)
    look what size your piston has.. order the same crank.. sorted
  16. antos
    antos New Member
    Amazing ;) thanks a lot mate giving me solution once again ...:) :yahoo:
