what am I doing wrong??????
Discussion in 'General Tuning' started by Myquad, Jul 21, 2016.
  1. Myquad
    Myquad New Member
    Hopefully someone can help?
    I have got a Generic race 50 for my son and have donre the following to it:
    Technigas exhaust
    Cone filter
    Race reeds amd block
    Derestricted CDI
    Rejeted the carb
    Made sure there is no washer in the Veri-thingy:)
    Made sure the carb is not restricted
    Opened up the exhaust port
    The bike has 10000km on the clock
    However the very best we can get out of it down a slight hill is 40mph
    Any suggestions?
    Many thanks in advance
  2. Stevep
    What size carb is on it?
    Why did you open up the exhaust port?
  3. Myquad
    Myquad New Member
    The standard carb which is hard to measure but I THINK it is a 14 mm
    As for the exhaust port, it was totally restricted due to the half moon shape that it had. Since opening it up the throttle is more responsive at low power however it still hasn't helped the top end
  4. Stevep
    I'm going to throw a shot in the dark here, but you've changed the dynamics of the back pressure considerably. In other words, by adding a sports exhaust, open filter, ported the head, you're letting the exhaust gases out much quicker than the air/fuel mix is getting in. I'm pretty sure you need to up the carb to at least a 17.5 and re-jet to suit.
    Check the colour of the plug as well, a nice dark ginger would be nice to find.
  5. Myquad
    Myquad New Member
    This had gone through my mind and the route of going for a 17.5mm however not sure which one to opt for with auto choke and premix.
    Any suggestions?
    Alternatively one with a Manila choke lever which will mean I will have to create a access pa el to the carb
  6. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    I agree with the above suggestion , fuelling diffnetely needs altering if exhaust and air intake has been changed , suggest a big bore kit too. Also are you 100% the cdi is derestricted ?
  7. scubabiker
    sounds like its a mineralli motor, or a copy of one at least, they have a 14.5 gurtner if i recall? those motors should do easy 50mph just with restrictor ring removed... +1 on putting a 17mm carb on there.... and ditch the cone filter and use either a sponge or an airfilter box...
