weird power
Discussion in 'The Workshop' started by chris taylor, Nov 18, 2012.
  1. chris taylor
    chris taylor New Member
    gillera stalker
    hi all my bike has been running sweet , but recently it seems to be boggy and hesatant on pull away to 15 mph then it flys through the midrange then splutters and bogs on top and starts to drop off speed , then if i roll the throttle off then back on its pretty much making no power and the speed starts to drop down to 30 mph where i splutter along the same thing happens if i hit even the slightest encline , if i pull over and stop moving then pull away it will start all over again, please help :(
  2. astro77
    astro77 Active Member
    have you tried the obvious thing's., plug, air filter, carb clean
  3. chris taylor
    gillera stalker
    yep multiple times , it has started this since i had to go back to standard reeds and reed block , it seems to have really upset it , will have to buy some new carbon reeds to replace my split ones, hopefully that will help sort things
  4. astro77
    yeah if it was running fine before, that may well be what's causing the problem then:)
  5. steveaerox50
    steveaerox50 aprilia owner
    1999 aprilia rs125
    I had the same problem with my aerox turns out the reed block gasket was shot so put a new one on and all is now good
