so ive changed my water pump seal on my jog rr around 3 times now and the still end up leaking after 2 weeks 1 genuine 2 non geuin hoping the correct fix isnt costly as im a poor apprentice haha
Is it just the seal that you change. If so, I would check the shaft and bearings. If the bearings are knackered, the shaft will have movement causing the seal to fail. Likewise if the shaft is worn or bent it will have the same effect. Pedparts for example do a complete kit for approx £10 This will work out cheaper than buying seals every 2 weeks or risking your engine overheating. the only other thing is possibly human error fitting seals> Good luck
If you check the shaft where it runs inside the seal it's likely the surface will be eaten away with rust and/or wear. Cheers Rob
