What should I do and what do I need to service my runner? I want to give it a good service as sometimes when I pull off it feels as though I'm pulling off in a higher gear so to speak. Like pulling off in 2nd in a car. Usually this happens on a hill start. If I was to put in stronger clutch springs would it be best to get lighter or heavier rollers? Starts perfect so the valve clearances are fine IMO Cheers Rich
Oil/ oil filter, check air filter, check belt/rollers, (replace at 10,000 miles) brakes stripped out, cleaned, lubed, clutch strip lube, check all lighting etc.
