VX Runnin rich after roller change?
Discussion in 'The Workshop' started by yoprice, Oct 17, 2011.
  1. yoprice
    yoprice New Member
    I change my rollers to standard 7.3g in my vx125 they where 8 somethings in befor. Since changin them when i open up fully it dies on me. Like its runnin to rich.
    They bike is a standard 125 with pm pipe and malossi filter in a standad box. As far as i know the jet is standard. Also has a new spark plug!
    Any one kno what it could be?
    It was runnin better with the old square rollers in :blush:
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    Yes. Your bike is running lean. You need to upjet. About 12% over standard. Should fix your problem then.
  3. yoprice
    yoprice New Member
    Wicked mate ta. Would that make sence then, it would work run ok with heavyer rollers?
    Also is it the filter or exhaust that makes me need the upjet, or both? Any ideas what make carb is standard and size jet?
  4. Jonnymarrw00t
    Exhaust makes you need to jet up, A insert filter needs 1 size at most tbh. I'm not sure on the jetting sorry, As never worked on a 125.
  5. yoprice
    yoprice New Member
    Ta buddy
