VIDEO LINK HELP
Discussion in 'The Workshop' started by CA Zip tuning, Mar 19, 2012.
  1. CA Zip tuning
    CA Zip tuning Member
    Surely this isnt healthy it sounds awful help please lads ? ???
  2. Duggiedan
    Duggiedan Piaggio zip 50cc
    Piaggio Zip
    Sounds like your mixture screw isnt right.. ive been doing some research cause i need to sort mine and you scooter has hesitation to set off, Guys correct me if im wrong, Screw ur air mixutre fully in not too tight and turn it out 2 full turns and start your bike up and warm it up, Then if still hesitates and struggles turn quater of turn clockwise till improves
  3. roxy boy
    roxy boy Well-Known Member
    roxi
    pretty much right yea....could be jet too big or flat spot on rollers ..and have you added anything to the bike
  4. CA Zip tuning
    i have 60 jet and yh mate a pipe and rollers thats it
  5. roxy boy
    roxi
    or this is faster and what i do ...start the bike and adjust the air screw so it will only run with choke on and then adjust it so it runs on tickover without choke
  6. roxy boy
    roxi
    what carb
  7. CA Zip tuning
    standard 17.5
  8. roxy boy
    roxi
    wat your rollers like
  9. CA Zip tuning
    havent checked them for ages bought fresh malossi 5.5s in october time i think
  10. Duggiedan
    Piaggio Zip
    defo check them your ment to change them every 6-12 months just check they arnt flat or worn as they tend to do wen more power
