Vespa et2 conversion
Discussion in 'General Tuning' started by theoldboy, Sep 17, 2011.
  1. theoldboy
    theoldboy New Member
    Hi all, About to convert my et2 with a sr125 engine, have the engine, carb, standard exhaust. No loom, what else do i need to complete this project, all advice very welcome, thanks.
  2. tErr0
    SR engine is a bad idea. Only wheel you will be able to fit that wont make the bike odd is a typhoon big drum wheel. 10" like the vespa but has a big drum that will fit the sr engine. You also will need to change the bushes in the engine to rubber ones otherwise you will get a terrible ride and a big risk of the engine cracking.
    You need an old typhoon engine to a completely stock looking conversion as then you can use a vespa rear wheel.
    You need a typhoon 125 loom with all the other bits such as the regulator to do it the easier way. Otherwise you will need an SR loom and a lot more head scratching. You also of course need a cdi, coil.
