Hi, can anyone help. I am a first time scooter restorer, and have just brought a 1965 Vespa VBB2T 150. Its back from the shotblasters and large section of the floor had rusted through. Being an ex metalworker i thought the best thing to do was take out the floor and replace it. All of the replacement panels i have seen are too wide for mine, and would mean cutting off most of the channel both sides for it to fit. This is not a major problem as the legshield/floor trims should cover it fine. I would just like to know if different widths are available or any other suggestions. Thanks Joe
You should be able to buy the correct size for your vbb floor try beedspeed or allstyles scooters you can also buy the stiffner pieces
