Very Annoying Problem
Discussion in 'General Scooter Discussion' started by zAaIronP, Jun 13, 2012.
  1. zAaIronP
    zAaIronP Typhoon 125!
    Piaggio typhoon 125
    I got a Piaggio zip 70cc.
    Modifications
    Leo vince ZX exhaust system
    70cc pmtuning aluminum kit
    NGK racing spark plug (BR9EIX)
    Polini Variator kit which included: variator with 6.3KG rollers, drivebelt, Tourque spring
    Polini high flow performance air filter
    Dorletto carb 21m (Have got TNT 21m carb, cant get it to work)
    Anyways problem is:
    my ped use to hit 70mph with standard variator (no polini kit) and 17.5m carb.
    must of drove 20miles home and on the way home it was boggy abit and wasnt running its best.
    next morning would not start, got it started the bike wouldnt hit over 40mph, put all the kit etc on it and its still only hits around 55mph which is kinda bollox for the money i spent on parts to get it running fast again. The bike doesnt start on the button takes like 5-7 seconds of eletric startin and open and closing the throttle. Once bike is started it and is warm, it idles high-ish then will drop really quickly, sometimes cutting out or will idle for few seconds then die. When i open it up to go faster, it sounds like it wants to go faster but it just wont budge, Used all sort of rollers, nothing.
    Buying a new piston ring tomorrow, but untill then, anybody got any idea's what so ever?
  2. Stig
    Stig Well-Known Member
    EXUP1000
    The high idle might suggest an air leak..split inlet rubber or crank seal gone...that'll alter the mixture. Try spraying some easy start around to see if the revs increase
  3. zAaIronP
    Piaggio typhoon 125
    Ive looked over the inlet manifold, there is loads n loads of tiny little cracks, gunna start the bike up tmoz n see if i can feel any leaks. Tried easy start not much difference.
    Thanks for the reply and the idea been dying for someone to say something :)
  4. Jonnymarrw00t
    Piaggio Zip 05 plate
    As above. I'd check your piston too. Replace the plug with a br9es. No need for iradium plug. Ps you're not doing 70;)
  5. zAaIronP
    Piaggio typhoon 125
    Checking the piston and bore tmoz, i shall give that spark plug a try, ok i was doin 67 (mate was in the car next to me) lol but its close enough to 70 ^.^ plus i had very high G rollers, the bike wud take of the line quick, die down then speed up n keep going
  6. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    Check you have strong spark too, my bike was boggin really bad today and had been hard to start. I cut some fresh HT lead and fitted it and now I have a really good spark and the bike runs great.
    Jonnymarrw00t likes this.
  7. zAaIronP
    Piaggio typhoon 125
    i shall test my spark plug :) i mite try that after i put new piston ring on.
    thankss
