Variator washers spacers etc. Problem Help!!
Discussion in 'The Workshop' started by TPH183MHR, Dec 8, 2018.
  1. TPH183MHR
    TPH183MHR New Member
    Can someone post a photo of variator washers spacers etc... Because i have forgot the correct order for both 125 and 180 thanks.
  2. MARSH
    The thickest goes on the crank between variator spacer/outer pulley, thin large diameter washer after pulley, kick start gear then smaller washer.
  3. TPH183MHR
    Ok thank you... my only mistake is that the thin washer was inside of the outer pulley and the thick one outside.
